Dooner
Did you change the coil? When I converted my car, I used both the module and the recommended flame thrower coil. Pertronix wants battery voltage to the module however, if your existing coil had a ballast resistor, which yours probably did, you leave that in place. Are you sure you didn't burn out the coil? Here's a diagram, which in short shows a resistor in line with the coil but the module gets full battery voltage. I believe Pertronix III has a rev limiter built in which you can program, they have a video to show how to do that. http://www.pertronix.com/prod/ig/ignitor3/default.aspx
Art, I used the stock coil on mine. How do I check if the coil is burned out? Do I just replace it and see?
I had a little time to work with the car. I noticed that my muffler was blown out like a balloon, so I went ahead and cut it off. I'm going to replace the small diameter single exhaust anyway. Might as well get the old muffler out of the equation.
I bought the unilite kit like I wanted, and for some reason it did not fit the distributor at all. So I put the Pertronix back in, and wired it up as the directions show, with the ballast inline with the coil, but the Pertronix wired into the hot side of the ballast. The Poly starts up pretty well now, but runs like hell. It at least runs now. It didn't before. I still have that same coil on it. It also could be the three year old gas in the tank. The car has been sitting there since it happened.
What should I try next?
