I would think Tim @ FHO would have pin-fit the Rods ? He does good work in my experience, but I can't quantify what as you said "
not overly tight" is for clearance ?
Just trying to Dot I's and cross T's to help you, again, maybe ask Tim if he did it ?
My opinion on open vrs closed chambers would probably be the same as anyone else's, while the closed chambers quench characteristics are an asset, the benefits are limited with cast iron approaching 10:1 on pump gas dependent upon how much Cylinder pressure you are bleeding off with the Camshaft ? And make no mistake here the
93 Octane rating available to you here in Canada is done so using Ethanol or Hydroxide group derivatives.... NOT pure Benzene rings(Gasoline), so proper jetting can be a bear without an Engine Dyno session to tune for it accurately.
In my experience,(and I haven't used one since the early 80's), the .509" with 248* @ .050 duration makes decent power up top..... but it is a pretty darn lazy Camshaft down low ? and Brake Vacuum is even worse ? IMO, Pretty BIG/LAZY darn Camshaft for a 2400 stall and 3.55's.... but the short 26" will help ?
You may wish to go see what the .509" does to Dynamic Cylinder Pressure on whatever targeted Static Compression Ratio/Head combo over here:
Static C.R. here:
http://www.wallaceracing.com/cr_test2.php
Dynamic Here:
http://www.wallaceracing.com/dynamic-cr.php
I thought this was a 'stock'ish' type build ?
400 to 450 hp goal ?
IMO,
248* @ .050 is getting up there a bit ? and would want Headers, Good Intake, 10:1, 3,000+ rpm Stall, etc., etc. and on 108* LSA Brake Vacuum is limited
just say'in....
might be some better grinds to look at ?
