Please Help with Seat Belts and Headliner Question for 70 RoadRunner
RoadRunner1970
1:35 AM
USA
Need to get all my seat belts back in my 70 Roadrunner the pic shows what belts I have left
I need to get the shoulder harnesses bolted back on but where does the little belt go? Also need to access behind headliner near edge of windows, can I remove the rail and see where the bolt holes are and the other clips that hold the belt? Can someone take a picture of there shoulder harness where it bolts in to car? Thanks
I don't have an answer for you but I do have a question for you. The manual calls for a spacer to be used between the seat belts and the floor. Just what is this spacer made of Steel or rubber and what are the dimensions ? Thanks.
I have a convertible 70 RR, but I will take a shot at the first part.
1. I think that shoulder belts were an option for 1970.
2. You are missing at least the two "seat belt rolls" for the passenger & driver side. These are 70-only and only roll out about 1/2 way.
3. I believe your short belt is either A. for center/left/right in the back seat. or B. for the center of the front seat (bench or buddy).
Now that I think about it, I believe you have the full set of seat belts for the rear seat and are missing all the front seat belts?????
I had a guy do the headliner but did not put all the belts back in so I do have all of them. The retractables and lap belts are in but I want to put all of them back in. I have to expose some of the headliner to see where the shoulder belts bolt in and there are clip holders that attach for the shoulder belts also. Thanks
can you take a pic for me of where the bolt goes in for the shoulder belt? It is covered up by the headliner and I cant feel where the hole is..... I need someone with bucket seats to verify where these last belts go if you can?
does the back seat have 2 or 3 of the long belts and where does he short belt go?
