Plug and wire suggestions MSD Pro Billet/ TFS 270
TexasRoadRunner68
2:20 PM
Dallas,Texas
What do you guys suggest for plug wires? MSD makes a 8.5mm kit, summit has a Taylor 8mm set, and I have also heard of the custom sets.
Also, what plugs for a street strip 512 with Trick flow 270 heads and 10.5:1 compression on 93 octane?
Personally, I would avoid Taylor’s. My buddy put a set on his Ford and in less than a year it looked like a lightning storm when you opened the hood after dark.
MSD are OK, I have a set on a 454 and they’re holding up just fine. I’ve run MOROSO on my 440 with headers, no complaints. I won a gift certificate for FireCore wires this summer. When the season is over I plan to measure up the MOROSO’s and have FireCore do a custom set to the same specs. Everyone says FireCore is top tier, I look forward to giving them a try…
Msd has a proven track record and you can buy spare parts
The wires are a crap shoot, as the test below shows. Use NGK 5 heat range plugs.
I've used all kinds of wires thru the decades. I buy bulk wire, boots, and connectors and make my own. I think msd and firecore are the same cable. Used Taylor stuff without issues. Buy the tool and roll your own. Somewhere along the line you'll always booger or burn a wire. With a few extra connectors and wire you can fix things and keep running, instead of begging someone to make you a wire.
