- 8:22 AM
- Dec 4, 2009
- Pasadena, Texas
Have access to an engine lathe that's big enough to swing them? If those bolts do come out, I'd go back with something with round heads....and do some little mods to them like bevel the outer part where the weights would usually go on a normal rim. Bevel the ID part of it. I might also put a 1/8" or 3/16" bevel on the round areas. Do a very small one (1/16"?) first to see if you like the effect but even a 1/16" bevel can have a good effect. Cast aluminum rims are usually pretty thick for doing stuff like that but it's a good idea to check the thickness with a spring caliper. I did that to some slotted mags years ago and it really made them look a lot better. Doing little things like that can make a big improvement.....
