Poly bushing lube
T2R9
5:14 PM
Conway, SC
What do you all use? My QA1's upper arms have fittings and am using poly strut rod bushings plus front and rear sway bar bushings. would like a mini gun tube but not seeing much out there. Any quality grease fine?
I believe the white/clear synthetic grease is what comes with poly bushings.
Has anyone else heard that you shouldn't use petroleum based grease on Poly bushings?
In the comments of the video I posted above there are a few people saying petroleum degrades polyurethane. Use silicone grease.
