lewtot184
i looked up the cam spec's for a stock '65 poly. it was 244 degrees, .400" lift. .050" duration is probably in the low 180's. the camcraft cam is significantly larger than a stock cam, not silly large, but may be an issue with stock log exhaust manifolds. keep in mind the poly cam is a different core than the LA318 core.
a 62-65 383/413 afb may be a bolt on. throttle bores ( 1 7/16" primary and 1 9/16" secondaries) may match up to the poly intake, linkage may be easy to do, and they're large enough for a performance 318 poly.
