Power Antenna
imperial388
10:59 PM
Cambridge, OH
Hello, Has anyone install a power antenna to there 64 Sport Fury, if so where was it purchased and how well dose it fit ?
I would like to install one of those on my 64 Dodge project. You can find them on e-bay, but I don't know how quality they are...................MO
They do list those at Classic Industries, but none specifically for a 64 B Body. You might have to use the "universal one." Your original 64 radio will not a have a circuit to raise the antennae, so you will have to rig up a switch. If you a newer retro radio, it will probably have the wire.
However, I also do not know how it will fit.
I installed an autozone universal on my 64 Fury Wagon. The original mounting hole is about 2" too far forward. The antenna motor hits the splash shield. The wagon is sort of a shop truck, so I had no problem drilling a new hole and using a plastic plug for the original hole.
Rick
