TonyB
I installed a rebuilt power steering pump and box in my 66 belvedere 318 poly. I used the existing return hose which is larger diameter on the box side and smaller diameter on the pump side. Problem is it is leaking some and I would now like to replace it. Nowhere can I find a return hose which is different diameter on each end. Every place I check you just get bulk hose. If I had not taken the hose off the car myself to begin with I would have thought something didn't make sense and when I ordered the other components, they came with different size fittings. Any ideas on where to get the right hose or other options.?
