Garys1969RR
I am going from factory rockers to Crane Gold Adj rockers with my 509 hyd cam. I need to know the best method for setting pre load on the lifters. My idea is to first prime the oil system to pump up all the lifters to max height, with the rocker arms off. Then install the push rods/rocker arms with the adjusters backed off a bit. Then set #1 cyl at TDC firing stroke. Then adjust that #1 pair by closing the adjuster till it is at zero lash, then tighten 1/8 turn to set the pre load. Does sound like the best way to do it? Any ideas appreciated. Thanks.
451 engine, 400 block. Eddy Perf RPM heads
