MoparThunder
I have my Pro Trans 904 Reverse valve Body 3 speed Tranny for sale, deep pan, alum direct drum w/ big piston - multi spring, alum forward drum, 245 gear set, steel carrier w/ roller thrust bearings, roller output support and reverse drum, 8 inch 4200 stall torque converter. There was no speedometer in the car when I got it so there input area is blocked. You will need to buy the components for a speedometer. I have upgraded my engine so I went to a built 727. It was in the car when I got it so I don't know much more than this. Never had an issue with it.
Asking $1,200 and can bring it to Carlisle when I come. I am going away to Oregon from June 7 - 12. I can respond to anyone's questions when I return.
