miller
On my 69 model 440, I've checked the part numbers on, water pump housing, p/s pump, and the brackets for the p/s pump. All are listed the right application.
I've also gone through 4 separate bracket sets, 3 the same type two-piece, 2 of those repops, and the one installed now, a good(?) used original.
Problem is, all of them give the same results, refuses to line-up with the crank pulley. Fairly close on the distance, but the p/s pulley is at a different angle, not with the crank pulley. Looking in line, from the driver's side, the driver side of the pump pulley is toward the rear, maybe near a 1/4".
What's the deal? And, the fix??
