okiemopar
- 7:52 AM
- Jun 1, 2011
- Durant, Okla. South Central Okla.
Will your points short to the rotor if they don't have a very tall push off? I thinking my new points are shorting out as it is running. Pull the points back out and the little part of them that runs on the rotor is all most even with the arm on the points. My other was burned up and I put these new ones in and haven't got it to run right yet. Gapping them on 19 and these are new but the little push piece is a lot shorter than the set I took off and another set I have. Just trying to get it figured out. It was running fine with the others till they burnt. Have a new dist so wiring is all good. Any advice on this will be a great help. This is a 70 RR with 383. Thanks Ronnie
