Well I got my pully off the TRW P/S pump, Now how do I take pump out, it's a pressed on pully, got that off, There seems to be a 4 notched ring on there, but don't know beyond that, Any help would be great. Thanks
Remove the 1 or 2 bolts on the back, and take the reservoir off. You will then see a large snap ring. Remove that, and then tap the shaft to push the rear plug out. After that, everything else will fall out.
There is a small hole in the casting where you insert a small punch to push the ring in. After that, you fish it out with a screwdriver. Yes, it does require some dexterity, LOL...
