Pushrod length
MprDoc
6:09 AM
Aiea, HI
OK, now, I measured pushrods for the first time today and basing it on what Lunatis web page said and demonstrated I think I did pretty well. However, do the intake and the exhaust require different length pushrods?? The camshaft is split duration, a lunati voodoo piece, BUT I didn't read any specific instructions for that on anyone's web page. The reason I ask is that on trick flow's web page they sell push rods for the intake and exhaust separately.
The motor is 360 LA with Magnum heads.
Trick Flow doesn't have anything for MoPars. You only need one length for your MoPar.
Comp Cams and Hugesengines .com have a decent read / write up on pushrods as well.
Yours are a hollow pushrod for the Magnum heads right? With the proper lifter to allow oil to go through... correct?
Wedge Head engines use the same length push rods, ...........The Hemi used two different lengths due to the unique valve arrangement.
Killer. I'm gonna go ahead and order through comp. Didn't realize how expensive push rods where but at least I can just mail mine in and get an exact length. Yes they are the hollow push rods and I do have the appropriate hydraulic lifters. Thanks for the help.
