Pushrod question
91r/t
10:58 PM
Buffalo, NY
Quick pushrod question. I have pushrods that are the correct
length ball and cup style on top and ball on bottom but they have small oiling holes in the ends. These should be no problem to use on my RB stroker correct? Correct length and 3/8 good quality just have the holes in them. Seems silly to not use them if there’s no adverse effects. Any opinions?
I would use them. Silly as I am.
Drilled through?
Well I was under the impression that all pushrods were hollow tubing not solid so would it matter? I think the only difference between the two is the tip with the holes in them versus without correct?
use oil through the lifter lifters AMC/ Magnum and oil the cups through the pushrods
Lifters already bought and paid for. Johnson lifters from Engle cams when I got the new cam for the build. Just was curious if this had any negative effects and it sounds not. I will use the pushrods and save myself $150 bucks! Always nice to be able to reuse something from the old build I guess. :D
