- 3:30 AM
- Oct 25, 2010
- Monroe, New York
Check your sweep pattern first on the valve stem, if this is too wide or too far off to the side you will require to relocate the rocker shaft. (most of the time with roller rockers you need to raise and move away from the valves)
I used the B3 kit to set mine to center and minimal sweep, see pictures.
By doing so you alter the length of the push rod.
Pushrod length does not change any geometry, the length is determined after the geometry is set.
Go for an as long as possible push rod, depending on the way of oiling (through lifter or from rocker arm) you will need to ensure the oiling hole in the rocker arm can reach the cup, if the cup sits too high it might not get oil from the oiling hole. But in that case it would be a design flaw of the rocker arm as it will force you to have multiple adjuster threads below the rocker arm.
If your push rod would be "short" you need to increase the length of the adjuster below the rocker arm, by doing so you will increase the "side way" motion of the push rod which will make you loose valve lift and puts a bigger angle between the adjuster and push rod which increases the side load on the ball/cup.
View attachment 1198745 View attachment 1198746
To the OP - There is some good and accurate info in this thread, and there is some info that is totally incorrect. You'll need to sort through it if you are compelled to "fix" something.
Here are other thoughs for you to consider:
If you change nothing from what you posted initially, your motor and valvetrain will live a long and happy life. The HS are very good and buying a different roller rocker would not change in any meaningful way the valve side rocker geometery. The valve side geometery would get better if you went with a non-roller tip rocker.
Some of the posts that speak to the lack of perfection and associated fix to valve side roller rocker geometery are correct. You'll just need to decide the relative importance of this lack of perfection, and whether you want to chase after it or not.
You or someone was correct in thinking that the pushrod length changes geometery. However, it only changes the geometery on the pushrod side of the rocker, not the valve side. Apparently, only the valve side geometery is of importance or discussed.
People way to much about geometry on mild cams. Theyve been running stick shaft locations for 60 years+. Make sure the adjuster isn't out to far. Make sure the pushrod and cup diameter are the same. Send it. Plenty more important items to worry about. He'll I've run close to .700" with the stock pivot location. Which is where the change needs to be made with a given rocker arm, lift, and stem height. You don't gain much dialing it in dead nuts under .600" unless the components you chose are really poor.
Doug
by sweep pattern are you referring to the contact line on the valve tip that the roller makes (cover in marker and run through a few cycles)? If so, mine seems to be dead on without any shims.
I’m at .600” almost dead on. Fairly aggressive cam but certainly not full blown drag car kind of stuff. I see what you mean. If it was a drag car then go crazy but for high performance street it’s less important.
Indeed, the contact pattern should be narrow and near the center area of the valve stem.
Depending on the brand/model rocker arms some might be close, some might be way out.
Mine were not so ideal so i used the B3 kit and reduced the sweep pattern by more than half i believe.
Some might disagree on getting this set up as correct as possible, though while you are at it why not make it as best as you can?
Going to roller rockers moves the pivot point of the arm up by .125" (with .250" diameter roller) from the base position which is ideal for a standard stamped rocker arm but can change things quite a lot for a roller type.
I did not see you mentioned how wide and where your sweep pattern is but depending on that i would decide how to proceed.
You can't possibly know this. Even motors on the verge of absolute perfection can fail.Here are other thoughs for you to consider:
From an engineering perspective, meh, not so much.The HS are very good
Actually, it can be quite substantial between brands.and buying a different roller rocker would not change in any meaningful way the valve side rocker geometery.
Both sides are important, but the pushrod side is less important, and designed into the rocker and that limits what you can do to make it better, unless you buy a custom rocker.Apparently, only the valve side geometery is of importance or discussed.
The old adage of "it's hard to teach an old dog new tricks" is very relevant.People way to much about geometry on mild cams. Theyve been running stick shaft locations for 60 years+.
This makes it sound like the higher the lift, the worse the geometry, when the opposite is actually true with a roller rocker. When I see these claims, I know someone doesn't fully grasp what true rocker geometry really is.He'll I've run close to .700" with the stock pivot location. Which is where the change needs to be made with a given rocker arm, lift, and stem height.
Do you mean like the design of most every Mopar roller rocker design, including HS, or the incorrect stand location in most every head for those rockers?You don't gain much dialing it in dead nuts under .600" unless the components you chose are really poor.
Doug
Actually, I joined back in 2013. I've just been an observer until recently. Thanks for the kind words.Mike at B3 Racing. He just joined our site a couple of months ago. He is a very knowledgable and helpful guy. Some very good reading in his tech tab on his website.
http://www.b3racingengines.com/
i did not know this. I always thought pushrod length is what changed the contact patch on the valve tip. As for the angle of the pushrod to the ball tip on the adjustment screw, is there anyway to know if the angle I have is ok?
I get it. Muzzle loaded rifles also have been around for a long time, and they work ok. But, if I had to go into battle, I'd be carrying a M16 or something similar.Not that geometry doesn't matter. But this stuff has been around a long time working ok. Now let's have some real world numbers of performance gains and failures from less than optimal geometry?
Doug
These are trickflow 240s with the trickflow "recommended part #" rockers?
I never made a claim that it wouldn't live a long and happy life. I just said it is wrong. It sounds like you are so confident the OP won't have a problem that you will pay for the repairs if he does. After all, you have no money invested in his build, yet you make a claim that you can't possibly know to be true. I didn't claim he would have a failure, only that the RISK of failure increases dramatically. If the geometry is correct, that is one more failure risk being removed from the equation.No more than you can can claim that it won't live a long and happy life. There are always extremes and exceptions Mike, but in the context of this discussion and application, I stand by my words. Experience does matter. I'm willing to wager that it will live a long and happy life. Are you willing to wager it won't?
Engineering is not the only measure of a product.
Because the of the factual nature of the differences between brands, we would likely agree on the differences. We probably would not agree on the significance of the "substantial" differences.
I understand the geometry. I'm not selling anything. I'm giving my open and honest opinion on a subject that I have experiance, and sharing it with those choosing to listen. They can make their own decision.
