nuteguy
Also, I was hoping to stay away from roller rockers. I don't see a need for them in my application since I am looking at a hot street car which might one day (hopefully) see a strip.
Would you like to elaborate on how it was corrected? As others may or may not know, lift at the valve dictates the optimum shaft height. If its incorrect, the shafts are in the wrong location. Push rods do not alter geometry on a shaft rocker system. So ideal geometry depends on valve lift for each application. I believe this is out of reach for the average street enthusiast.
Doug
I'm running the cam that came with Edelbrock's top end kit. Its nothing crazy. Here is the card:
http://www.edelbrock.com/automotive/mc/camshafts/locator.php?part_number=7194&submit=go
On that card, which I actually just noticed, is the only place anything is mentioned about adjustable pushrods or rocker arms (Footnote 1)
While true that you adjust lifter preload on the base circle of the cam or heel, you should not be backing off the adjuster 1/2 turn. While on the base circle of the cam back the adjuster off enough to get a feeler gauge in between the valve stem and the rocker arm, the feeler gauge should be whatever the recommended preload is for the lifter. Then turn the adjuster in just until the pushrod will not rotate by running your fingers across it. Remove the feeler gauge, count the turns on the adjuster until the rocker arm contacts the valve stem, now turn the adjuster exactly that same amount again to set the lifter preload.An update:
I got hold of some Crane Cams adjustable roller rockers and pushrods. They are now installed and ready to go. I initially adjusted lash by finding zero lash (where I could not move the pushrod up and down at all) and then went a half a turn past that. After speaking with the engine builder who did my machine work for me, he recommended finding the bottom of the lifter and then backing off a half a turn. That way at higher rpms when the lifter does not have enough time to preload, it does not collapse itself and create a lot of lash. I adjusted following his advice yesterday. The lifters still have some travel and I can still spin the pushrods even though it was pretty difficult. I did have on oily gloves and there was oil on the pushrods themselves.
Also, I should note that I test fit stock pushrods and rocker arms and they seemed to work perfectly fine in terms of clearances and angles. Granted I'm no professional engine builder but I didn't see anything critically wrong with them.
An update:
Great reply, Ron. Saved me from writing it....thanks.
