Lbone
I have been trying to absorb all the info I can about putting disks into my 67 charger. Originally I was going to go with a disk swap kit from summit but found that the mishmash of parts from different vehicles to be to confusing so I have been looking at using a newer donor car.
Info on this is somewhat vague so I just wanted to run it past you b.b.o guys and get some input. I have a 1979 cordoba with disks I can get the spindles, dust shields and sliders from, will this work without having to change control arms? All the other stuff I plan on buying new, rotors, pads, bearings, seals, calipers, master cylinder, proportioning valve and brake booster. should I buy the brake booster , valve and master based on a 79 cordoba and does it matter that my car has manual brakes right now as far as bolting all this stuff in?
