David Womby
This is for my 360-powered Bristol 408.
The goal is for the electric cooling fan to run under two circumstances
1 - whenever the thermostatic switch B triggers it because of high coolant temperature. This should trigger the relay at D regardless of the ignition being 'off' or 'on'.
2 - whenever the manual switch A is turned on but only if the ignition is turned on.
Sorry - I was born and raised in the UK and still write 'earth'. US translation = 'ground'
My main question is: is there any danger if the ignition is 'on' and both the thermostatic switch B and the manual switch A are 'on' simultaneously. I think it should be OK. It means the relay at D will be getting +12v from both sources but I don't think that's a problem and I don't think I need diodes to protect the two switches, do I? Or do I? Any help will be appreciated.
David
David
