Racepak? V300SD or Sportsman
ironside
6:48 PM
MI
What are you running, how do you like it etc??? I keep looking at the sportsman model but worry some about not maybe doing all I want I guess.
Going to be used with Msd 7530 for me.
Shock travel
Rpm
Oil pressure
Input shaft (4 speed)
Water
Maybe fuel press
Driveshaft etc etc.
Thanks for the input.
IRONSIDE, sportsman should be enough but im looking at the v300sd, its the new technology with sd card, pull card and download. i like that feature. it is more money but the sportsman isnt cheap either.
SSR Shut up until you buy a Racepak hahahaha
The technology is the same, the Sportsman also has an SD card that you pull out, they are both vnet connections
The Sportsman comes with driveshaft speed, engine rpm, volts, lateral and longitudinal g force Thats 799
You can add 6 more channels out of the box and racepak just announced that you can add more channels than the 6 with an update from them. Im sure they will charge per channel or something like that.
Call Joe Oplawski at Hyperaktive Performance Solutions 847 321 1982
There isnt anyone more intelligent about Racepak.....and his customer service is 2nd to none!
Great. Thanks for the help. Some of the sensors are pricey jokers. Haha
This is great info. Thanks. I was planning on buying a Racepak after speaking to a user and getting a demo of his data. Looks to be very easy to use and the info you get is worth it's weight in gold.
