the dude 00
Hey guys. My 1968 gtx has a missing radiator shroud. After a little investigation, I discovered that it's not the original rad. It's actually out of a 1973 c body 440. I'm having heat issues in hot weather when idling(what else is new). I was told the rad was recored,so I thought getting the shroud would probably solve my problems. There is four bolt holes for shroud mounting and their spacing is about 11.5" apart. I can't seem to find a shroud with said spacing and I'm also wandering if the fan alignment would be okay,considering all facts. Question is, do I bother with shroud,hoping I can find one that will fit and solve my heat issue or just buy an aluminum one with everything included,being that it's not the original rad anyways? Any guidance or opinion will be appreciated. Thanks!
