Paul_G
- 1:45 AM
- Dec 24, 2013
- Surprise, Arizona
Low compression 1976 440. Has been rebuilt using stock pistons, new rings and bearings. 452 heads with unknown springs. It has a smallish Comp XE256H cam, 212/218 @50, .447/.455, 110LSA. I had this cam and lifters so they went in the engine.
The car this engine went in has an F1 Procharger in it making about 10 PSI max. Now here is the problem. Just over 5000 RPM, full throttle, the engine has a rapid fire pops out of the carb. Otherwise it performs really well. Runs smooth, pulls hard. Idles like stock.
The trans wont shift yet at 5000, so I cant really flat foot the throttle. Been all over the thing trying to figure out the popping. AFR at WOT in the mid 11's. Timing from 2500 on up is 29°. Best I can come up with is weak valve springs lifting off the seat.
