Have not been able to look at the car yet, this is the last message I got from the seller:
"My BS meter runs high and pretty accurate with the responses I've gotten on this car-which has been a lot. Everything is subjective in relation to the value of this car. Problem is I own it. You would rather look at it vs get pics of the car sent to you. Problem with that is, it involves more time for me vs sending more pics of the problem areas on the car (which I already have), which is the whole car practically as seen in the pics on CL. If you are not at least prepared to buy this car for 16k-(done ones are in the 60 range), put 10k in sheet metal on this car, that's the cost of the metal and not the labor, then this car is likely not for you, plain and simple. Frame rails are a huge issue with this car in the back as is the case for most project 68-70 chargers, there basically are none, which means no trunk too. The fronts are pretty nice except where you get into the cross member area. If this car was solid, which its not even close, we would be talking in the 30 range-easy. I'm purposely trying to scare you, as this type of resto is not for everyone-very few actually. The one good part of this is you know what you have after you do it because you will address every area of the car before you are done. Buying a done car has its + and - attributes, I focus on the negative as you never really know what has been done when someone else does it, even with documenting with pics along the way. Automatic 68's are dime a dozen. This car is close to you, but its rough, but also no shipping or driving charges per se. I hope this sounds "crazy" enough for you to not want it anymore as I'm not moving off 16k as I subjectively feel its worth that, and I own it, and I really don't care to see it go or need it to be gone. Go find another.... locally....even nationally...These 68-70 R/T's are hotter than cuda and challengers for once, especially the 4spd cars. Your're not the only one that wants to "look" at it and if I multiplied 1hr x approx # of prospects, thats a lot of BS time. An Ebay ad is more expensive but its somewhat of a binding contract and a general BS detector. I'm not looking to take anyone, I would have extensive photo gallery and let it fly. At the end, hopefully I would find a serious buyer with the $ to purchase it and the $ to fix it and a trailer to come pick it up and not BS around condition after the sale-that would all be done beforehand. "
For some reason it seems like he is doing his best to tell me I am not welcome to come look at the car...
