PurpleBeeper
If I do need a new rear seal, what brand seal and sealant does everyone recommend?
I've had good luck with the Felpro seals, but I see Cranky prefers the "rope" type. Don't forget to put a little dab of RTV silicone on the lower corners of the rear main seal retainer at the seams and where the two halves of the rear main seal join each other. I've heard that can leak too.
Felpro type - they go in one direction & it matters (can't remember lip forward or lip backwards?)
Rope type - make sure to cut off the little bit extra "rope" with a sharp razor blade. These probably seal better, but you need one of those "Chinese finger lock" tools to pull in the top half of the seal over the crankshaft.
