Rear suspension ride height
bulldog red
12:53 AM
kathleen,ga
Read the post below on ss springs.I am wanting to raise the ride height on my 67 Belvedere.The car was originally a six cylinder,but now has a Hemi,4sp,83/4 axle.I am assuming the rear leafs are stock.I would like to know the best route to raising the rear a little,it's just too lowrider in the back for me.This is a street car.Any suggestions?A rear leaf spring change if it would accomplish my goals is not out of the question.I do drive it fairly aggressively,but i'm not dragging it,thanks.
Adding leafs increases the rate. If your happy with the ride and it's not bottoming remove the springs and take them to a spring shop and have them re-arched. You'll have the same rate spring at a increased ride height. Dave
Was a 6 cyl car. Does that matter?
Well, the 3400 lb ss springs in my 62 B body raised the rear close to 2", maybe a touch under as measured from the rocker in front and at the rear. They are not harsh at all and I like the ride. Hope they settle a little. If you go this route, you will need a different front spring bracket as your front segment is not 20" and longer shocks to allow the springs to work.
Everyone said get stock ones re arched but there isn't a shop anywhere near me that does it. ESPO is good but shipping isn't free. My decision in going with the ss springs was price. $117 each from Summit and $8 for oversized package. And they were at my doorstep in 3 days.
If you have a Hemi and a 4 speed in a car with original 6 cylinder springs I think you need to look at more than height adjustment. Stock GTX springs for 440 or Hemi have six full leaves on the drivers side and 5 full leaves plus 2 front half leaves on the passenger side for traction control as much as handling. You should start there, although they set the rear at stock height. I'm no expert on S/S springs but a lot of people seem to use them to raise the rear along with better than stock traction control.
With a Hemi 4 spd you sure need the Super Trak Pak XHD springs or the Super Stock springs. The SS springs may sit a little higher than the XHD springs. I do have a pair of ESPO springs for a '66 -67 that have a total of about 3000 miles on them that sit at a stock height . They are great. I'm going to a pair of SS springs I had, since my main use will be drag racing. For street or limited strip use these ESPO's are great.
Thanks Don,what you described is exactly how my car is set up.
Threewood ,do you have the part # for those fwd brackets?
