fmontez1
I have a 68 coronet 500 that I'm working on. I put bigger tires in the back, and now I get a little inner fender rub on harder turns.
I'm about to start working on stiffening up the rear end. The front end was recently freshened up when I got the disc conversion done, and I already have a sway bar in the front where I do not in the back.
To that end, I'm going to buy some Suspension components, and I was wondering which you all thought would make more difference first.
The anti sway bar, or the XHD springs?
I was thinking of this Hotchkis Setup for the rear sway bar, and I was gonna get these Springs from Mancini to try and bring the rear uip a little bit, and also because my springs feel really saggy and soft in the back.
What about these Hotchkis Geometry correct springs? Is it really that big a difference for the money? Anybody on here use those?
The car will be driven in the street, and occasionally the strip. It only has a 318, but eventually I will be popping a crate motor in there, so I don't mind buying the bigger rear end stuff now.
Which will give me more bang for my buck? What about shocks, what do you guys recommend? I don't want air shocks in the back. I want to address ride height with springs and let the shocks do only what they're supposed to. I don't mind a stiff ride, this car isn't going to be built for comfort.
Any tips about either install;ation would also be appreciated. I have a good idea how to do it, I'm sure I can get through it, I know I've done it before at one stage or another.
