Mike Gaines
- 9:20 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
thanksThe motor is out of the car right now. I'll take a pic of the plate tomorrow.
Doug
Doug
Interesting. Might come in handy for some readers...Here's a few pics. You can see how the nose is bent down. This could be done on the sides as well.
Doug
View attachment 590800 View attachment 590801
---Like I said above....I can't seal the carb, even with a drop base, because the carb sticks up ABOVE the hood. A drop base will not rectify that situation....and...I don't want to remove my 1" spacer as it is important for my performance. Thanks. mike
DVW.... You have your act together with that carb plate that you are running. Back in the early 70"s I raced a 67 R/O car and we actually used a large pizza pan with hvac tubuar foam around it to seal to the hood. Same theory. Last but not least, if your hood is raising in the rear put another pin at the rear center location. Then you will see how good your hood and scoop is mounted.Here's a few pics. You can see how the nose is bent down. This could be done on the sides as well.
Doug
