- 1:45 PM
- Jan 23, 2009
- New Jersey The State of Tax Theives
Voltage drop only tells you if you are drawing system down not how many amps are demanded.
It likely puts out 6-10 amps if that at low idleCurrent alternator is a basic one from advance auto and is 60 amps. The fans draw 30. I have the fans driven off of the alternator, and now I have an MSD 6A ignition box wired to the battery. Condition still exists. It’s a basic car electrically, no power windows or doors, am radio, and lights. I read that going from a 60 amp to 85 amp alt doesn’t require a wire size upgrade. Sound correct? Would I need to go larger on the alternator?
Sonny
ThanksLate to the party anytime for me I upgrade something I always upgrade what's involved. Your fans will pull more load at a light because of that factor the alt wiring can't give you more amps. So upgrade is needed. Also next time your looking at the alt pulley did you use the old one or upgrade it to the amps that it should be. Some alt pulleys are different size. Better yet I should say each alt pulley is made to help produce max out put so if the new is 4 inch round and the old one is 6 inch round and you used old pulley on new alt it won't produce what your after. So between the wire being wrong and the pulley being wrong then your problem will never get cured. Good luck and just my 2cents.
I bypassed the ammeter by bolting the terminals together some time ago. Fans are hooked directly to alternator. MSD ignition off of battery.has being told the 100 amps alt from tuff stuff is able to put 60-5 amps out at iddle.
now... do you have the stock cluster ammeter still conected and working ? If you do, is wrong source anything from batt
I have dual 12” fans and the instructions said they together draw 30.60-65 amps
next to consider... fan consumption. Yes relay says is able to handle 30 amps, but who says the fan sucks that load ? Relay is not a load sucker so despite the relay specs and check the fan specs. Modern fans are able to be handled on 16 or 14 gauge wires, and most on them get the pigtail made on that wire size. I don't think your fan will suck 30 amps really. I'd say more like 18-20 amps
