Removing the drag link from the idler arm on a '65 Dodge.
fullmetaljacket
1:36 AM
Brooklyn, New York
A 1965 Dodge Coronet. Does anyone have a recollection of what tool they used to remove the drag link from the idler arm while still mounted on the car? Any tricks or perhaps a pitch fork?
I haven't done this in ages and just plain forgotten.
I loosen the nut, place a large hammer on the back of the joint and smack the joint 180 degrees opposite to the large hammer. Kind of like hammer & dolly body work, the blow energy stays in the joint and will dislodge it.
So as to clarify, place a hammer head on the body of the idler arm by where the joint is and hit the other side with a hammer to shock it loose?
The part that the tapered stud goes thru gets the whacking. That will jar it off of the tapered stud.
Yes, what I would call the joint housing area. Obviously not the arm. Thank you.
My friend Special K is going to lend me his arm puller of a different style that should work.
FSM states use Tool C-3891, though I've never saw one.
Just to be clear….you smack the drag link, on the side of it & don’t be shy about it. Whack it HARD
AutoZone used to loan the puller like the one pictured in #11, but no longer. They have the cast aluminum c shaped puller that just doesn't work well.
Where's a good place to buy the puller pictured in #11?
