Cajun Ace
I tried to replace the left hand wheel lugs on my 1968 Satellite and ended up cracking the left wheel hub. Have looked around LA and can't find replacement. Looking for a used replacement if I can find one.
you will need to get the new studs swedged on as well.you prob damaged the drum if you pounded them out.might be a good time to look at disc brake conversion if your buddget allows and no one has a hub.
