I picked up a used trunk panel several years ago that was in fair condition but had one dented area along the top that I mostly massaged out some tim ago. I decided to finally get around to finishing it. First thing was to strip the anodizing use lye crystals and a dipping tray an air conditioner mechanic friend made for me.
Submerged for 35 minutes
Out of the stripper
Rinsed off
Working over numerous dings and sanding down for polishing. Realized I forgot to remove all the paint in the letters which protects the anodizing from the stripper so had to go back and touch those areas up. Sanded down to 2500.
After polishing with two grades of compound and cleaning with Mothers aluminum polish. I didn’t sand out every last ripple in the flat panel areas or polish those areas as they get a flat silver paint.
Masking off for paint
I’ll try and paint in the next couple days using a light coat of SEM etching primer and Krylon 1403 dull metallic silver in the flat areas and red in the stripping areas
Out of the stripper
Rinsed off
