Reverse Harness Hookup Help
superbird77
8:02 PM
West Michigan
I am installing a new reverse harness on my 69 RR w/ 4 speed manual trans. There are three connections that are supposed to plug into the bulkhead but i don't know what goes where. Can anyone help me out with this? One wire is purple, also a black wire and then two black wires going into one connector making three total connections i need to plug in. This is the harness that comes from the transmission FYI. Thanks!
Not sure if a 69 is the same but for 70' I believe it was 2 wire from the switch 1 went to D and the other 2 (that were tied together) went to C and Z but it all plugged in.. I think mine were all black though, you sure you didnt get an auto harness.. Although this may not be the same on 69, I can look on my 69 later today if no one chimes in.. My automatic 70 has 3 wires 2 black and one yellow, my manual 70 has 2 wires on the tranny switch but one of them splits from the connector to Z...
I went back to the vendors (M&H) site to confirm its for a 69 RR w/ 4 speed. The two wires going into a single connector are black. There is also one single purple wire and one single black wire.
