Reversing polished aluminum ?
1962polara
8:15 AM
alaska
Need some info & help ..... I have a polished crossram intake manifold and would like to have it back to "as cast"
Could anything be done to get it close or is it unattainable ?
thankyou
Take a can do "heavy duty easy off" and spray the snot out of it. Let it sit for about 20 minutes, the polish will be gone and you will have very dull looking manifold. That's the best advice i can offer.
I've done a light sand blast and seems to work decent but tape off any areas like the carb flange and mounting surfaces
Of course, being a Mopar you could use textured argent silver grill paint and it would look pretty good. :)
:HappyNewYear:
How ever you decide to do it, we would love to see the finished results ! !:VB toast:
thankyou
Would lit sell for more polished than other used ones that are not polished go for or perhaps someone would trade with you that wants the polishing work ??
Just an idea
Just an idea
X2...That sounds more reasonable to me. Sell the polished one and buy a cast one.
OR
Maybe CudaChick could help you out.
FYI, the Glass Bead process puts a shine, a sealing shine on natural metals. It closes the pores of the metal, so it won't really dull it up, it will shine it up! A good, fine Alum Oxide mixed in with some Plastic would yield a superior finish. Send it down, UPS/FedEx delivers daily. I'd recommend NOT doing something as nice as this Cross Ram Manifold with Easy Off Oven Cleaner or anything else, do it once, and do it right.
Yeah, I used Easy Off on something on the recommendation at another board and I didn't like the results either.
sand or plastic bead blast that puppy, it will look like a new cast manifold, I've done glass beading on a few aluminum & magnesium parts/manifolds they didn't look polished at all to me, more of a softer sand blasted less course/textured effect... JMHFO thou, I don't blast stuff for a living, like Donny does...
Wow that's some great solutions!
thanks.
The casting no. has been polished off & the date but for what it cost I'll see what I can achieve .it is a nice polish job and I may just paint and check results.I'll post pics regardless...thanks all again
Donny I'd send it to you if I was in the US ...cheers
There are lots of different medias for blasting so I'd check with a supplier and see what they say. Or the best result would be tallhair's suggestion. Find an as cast one and sell yours.
thankyou
YIKES!!! I have to guess that you've never gone through all the time, effort and elbow grease of polishing raw aluminum. Please reconsider it on that crossram ... or sell it to somebody else and buy another one. I realize it's your part and your car, but somebody went to a lot of trouble and expense to get it that way.
5.7, with all due respect, that's absolutely terrible advice. Leaving caustic lye-based oven cleaner on any metal for longer than a couple minutes is going to do more harm than good -- especially aluminum because it's so porous -- and all the original poster is going to be left with is a chalky, uneven, splotchy finish. Once that stuff dries on there, he's NEVER going to be able to get rid of the residue.
Commercial oven cleaners can be used to remove anodizing (if you know how to do it) but I'd never recommend it on polished aluminum.
There are two basic ways to etch the surface of aluminum to remove the polish- caustic vs acid. Acid is the better, safer and cleaner way to do it. The oven cleaner is caustic. Lye is sodium hydroxide or caustic soda. It will remove a significant amount of surface material- more than acid. It works well at taking away a lot of material, but the residual is hard to deal with and the process is much less safe. In years past, it was the most common way to etch aluminum and to prepare it for anodizing. Acid is much cleaner and safer. A simple water bath will dilute and clean away any residual. The remaining aluminum will sludge to the bottom of your bath. Phosphoric acid is probably the easiest and most readily available. Coca cola has phosphoric acid, so if you leave it in a bath of coke long enough, it will etch the surface. Phosphoric acid can be bought at any home improvement center. TSP works too. Hydroflouric acid is the one more commonly used in industry. However, fluorine is extremely toxic and should be done with good ventilation. Hydrochloric acid will also work, but is the strongest of the three. In any case, you want to work with dilutions and the time the aluminum soaks to get the optimum results. If you are really patient, you can also try vinegar. It will take awhile, but eventually it will etch.
