Right stuff brakes.
So it was a pretty successful conversion today. Removing the old master cylinder was a real pain though. Getting under the dash isn't as easy as it used to be. Three of the nuts were pretty easy to remove. 1/2" deep socket, extension on the ratchet, universal joint for the top left nut. The top right nut was the challenge. The deep socket didn't allow me to attach a u joint on it.
a regular 3/8" drive 1/2" socket wasn't deep enough to get on the nut, the stud was too long. I didn't have a 1/4" drive 1/2 " deep socket, which might have worked. The 1/2" drive 1/2" socket with a 1/2" u joint and 6" extension allowed me to finally back the nut off slowly. Unscrewed the nut and bolt connecting the push rod to the brake pedal and the old MC came right out ( drained the fluid with a turkey baster and disconnected both brake lines before I started nut removal). Planned on using the old studs and nuts to attach the new Right Stuff master cylinder. Ran into my second challenge there. the holes on the new MC were bigger and the old studs just spun around and there would be no way to tighten them unless i held the round head with vice grips. Given how hard access was to the nuts under the dash, I opted to use some 5/16 x 1 1/4" grade 8 hex bolts with lock washers and nylon stop nuts. I know it's not original but I didn't want to interrupt the install to search out studs that fit, so I used the hex bolts. I put the nuts on the engine compartment side to make it easier to install and any future removal.
Before I installed the new MC, I bench bled it. Got a kit from AdvancedAuto for $7, had different threaded hose connectors, hose, clip to hold the vinyl tubes in the brake fluid and plugs to plug the hose after bleeding. I used the old push rod to pump the MC. Didn't take long till it was just fluid pumping thru and no more bubbles. Installed the push rod with a new rubber retainer,used some dielectric grease on the retainer to help push it in. Bolted up the new MC and reconnected the pump rod and brake lines.
The proportioning valve was pretty easy to install. I used 2 30" pre-flared 3/16" brake lines and one 3/16" flare union. I had to bend the lines to make it fit. I mounted the prop valve on the fender wall using an existing hole and a 1/4" bolt and nut. I disconnected the rear brake line from the distribution block , used a union to connect that to the out line on the prop valve and the in line on the prop valve back to the distribution block. I then proceeded to bleed the whole system. Used the traditional 2 man method, one on the bleeder, one pumping the brake pedal. I used almost a full quart of Dot 3 brake fluid and got a very nice firm pedal when done. I kept the prop valve at the midway point since the instructions said that's where to start when adjusting. That brings me to the next challenge. I took the car for a test drive. The brand new front discs were a little squeaky. And, the car was stopping very good even without the pads and rotors not being bedded in. The challenge was adjusting the prop valve. I could not get the rear brakes to lock up. I adjusted the prop valve multiple ways, all the way increased, all the way decreased, and different settings in between. The rears would not lock up at all and the car stopped straight and fast. I'm not complaining as the brakes were working great and a big improvement over the old drums. But, I wonder if I even need the prop valve to begin with. Maybe I'll disconnect it and see if that makes any difference. Another issue which I didn't get to address yet was the brake light on the dash is always on. Not sure if I disturbed the wire on the switch in the distribution block or if some dirt got in there when I plumbed in the prop valve. But, I know both front and rear brakes are solid and working, with no leaks. Any ideas?
Overall, the whole conversion was pretty problem free. The SSBC kit fit perfectly, the 15/16" Right Stuff MC gave me a nice firm manual pedal and the car stops straight and fast. I'm assuming as the pads bed in the braking will be even better. Here's some pics of the install.
I looked at the PDF.. I was correct. They do mount on the rear. If you scroll down the PDF you will see they show the driver side spindle front and back. The caliper bracket is on the rear side of the spindle. The master cylinder that came with the kit was messed up and would not bench bleed. Lucky for me we were going back down to Summit and just took it with us and they replaced it.
https://www.getdiscbrakes.com/pub/media/wysiwyg/instructions/MDC62DC_MDC66DC.pdf
Step 7.Once the brackets are on, you need to determine if you want front or rear mounted calipers. Most application use rear mounted calipers. If you want to run front mounted calipers, you need to reverse the spindles (left hand to right hand and vise versa). One of the determining factors of front or rear mount is the final flex hose routing. Test fit the spindles as both a front mount and a rear mount to see which setup would give you the best flex hose routing to the factory flex hose frame bracket. After you have determined if you are going to front or rear mount your calipers bolt up the old steering arm assembly (or new steering arms for A-Body owners) and torque the hardware to the specifications provided in the factory assembly manual.
In step 8 they show the passenger side caliper with the bracket towards the front. I guess it can be either way.
I'v read somewhere that the proportion block can be reset.
If you have a front sway bar calipers are rear mount.
I have used the Right Stuff, not SSBC. I like the Right Stuff, quality components. My suggestion, get EVERYTHING you can from whichever company you decide. That way if you have an issue there is no room for them to blame another mfrs component. My only other suggestion, if you are considering a rear disc conversion later, maybe consider Wilwood and others right now. I like the Right Stuff quality, not a fan of their rear disc conversion design that I have installed. I much prefer Wilwood's, which uses a hat rotor design. Good luck, have fun.
What dia rotor did you go with? I did not see a big rotor option, assuming the listed 11” rotor is not an 11.75 but rather a 10.87. I am struggling to decide what size I really need (70 RR with 440).
I used Right Stuff brakes on a Nova race car, 11-inch rotors. I believe 11-inch will work for your app., but I'd go as big as your selected wheels will allow.
I am putting the right stuff power 4 wheel disk conversion on the '69 Coronet R/T
The car was originally manual 4 wheel 11" drums.
I had to rear mount the front calipers because I have the factory sway bar.
The issue I have with the rear disc brakes (besides them being shipped with the wrong instructions) is that the factory length parking brake cables (for the '69 Coronet) are about 2" too short, and it seems no one sells longer cables. The kit came with two equal length cables that might work on a 71 up B-body or E-Body?
I made some 2" spacers at the frame connection where the brake cables normally attach and lengthened the parking brake adjuster cable part.
I'm still working on plumbing the front brake lines. Having a hard time installing the passenger side brake line with the engine and everything in the car. I think my speedometer cable is in the way right now.
The power brake assembly is fairly big. I haven't installed it yet as still need to get that brake line installed first.
I hope it get back working on it this week. Been messing the the EFI on the '71 Charger the last few weeks.
Understand what your are experiencing with the parking brake setup. I looked at hooking one up on the Nova, but with roll cage in the way of the foot lever, I'd have to run a tunnel hand brake, so I just left it off. I like the quality of Right Stuff products, especially their brake and fuel lines, instructions are a bit special. But they were helpful on the phone. Good luck, show pics when done.
It looks like you're having the same problem as I am, with the Right Stuff parking brake cables not being long enough. You mentioned that you made some "spacers" at the frame connection, can you post some pictures, so I c an have a frame of reference? Mine seem to be roughly 6.75" too short, and finding anything to fit has been darn near impossible.
Be aware that if you buy the proportioning valve from Summit it comes with the wrong instructions.. I had to download the PDF from summit for that. The one that came with it was backwards. This is the one I bought. Summit Racing SUM-760184 Summit Racing™ Brake Proportioning Valves | Summit Racing
I hope they fixed it by now.. But it was wrong.
Here is the PDF link for the instructions.
https://static.summitracing.com/global/images/instructions/sum-760184.pdf
@BeepBeepRR this is an old post but did this valve from summit plumb up just like the original factory configuration? Their instructions and customer service/tech assist responses are conflicting.
I really need to find a place that makes custom length cables. First, the rear brake cables I am using are the factory replacement drum cables, not the cables that come in the "kit".
The main difference in length is where the cable would have gone into the drum backing plate to where the cable holder for the disc brakes is located, about 2"-3" difference?
The "spacers" are just two pieces of tubing. The larger tube I believe is like 9/16" 8th wall? 1/2" inside diameter that the original cable end at the body mount goes through. I mahe this so the cable end slips in and the tube moves the cable back 2" or 3" from the mounting holes in the body. I then took a 1/2" OD tube and plug welded it inside the larger tube as a guide to go through the body mounting hole. I made it extend past the hole so I could use a collar clamp on the front side to hold it in place. On the larger tube, where the clip would have held the original cable, I drilled and tapped a small hole for a set screw, but the tubing is really too thin to really have any threads to put any torque on the set screw.
Because everything is moved back from the body mounting holes, I had to extend the adjuster rod part of the cable going to the E-brake pedal with a coupling nut and some all thread rod so the part that pulls the inner cables would reach.
The car is in storage, so be awhile until I can get a photo.
