Mike Gaines
- 5:51 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
If you RULE OUT old oil/filter and or improper installation what life should you expect with your rod and main bearings ?
I change my oil and filter every 30 runs.
What component/feature of your motor build shortens bearing life ?
14 or 15-1 compression ? Is this the biggest culprit ?
RPM
or what ?
My motor has 12.2-1 compression and I shift at 6200 1-2 and 2-3 and go thru lites at 7000rpm.
What should I expect out of my rod and main bearings ?
PS: Nothing is broke, just wanted to start thinking about if I should
be checking my bearings soon.
RPM
or what ?
