Someone had mentioned to me about setting up some better air flow on the front of my 68rr. I think some better air flow under thr front end may help. He also mentioned the wheel wells also. Looking at that but thats a tough one not sure just how to get that to flow smoother. I am doing disc brakes in the front as we speak and that should save a good amount of weight. On my 04 viper the whole bottom is an al. sheet.
That was no doubt me...
Redirection of air going into the front end tapper it inward, to go thru the radiator
& not under hood or underneath the front end...
A front splitter or air dam/spoiler of some type, to redirect air from under the car,
would probably help some too...
My main point was/is;
Installing basic inner fender-well panels also...
Just keeping air from making it a big parachute like effect,
grabbing air while going down track, that will slow you down...
Even just a simple flat alum. panels, like were/near the orig. inner fender-wells were,
or from frame rail to top on diagonal bars {if it has a cage, front bars},
then a 40*-45* bend {what ever angle} to go back up-to the fender lips...
That would help keep air out from under the front end somewhat better,
anything is batter than, a completely open engine compartment,
With inner fender-well panels, then only the wheel wells would catch the bulk of the air,
going from the front end that way...
A belly pan {sheet closing off the air from under the engine bay},
that could also help some too, but the heat & stacked/trapped air needs to go somewhere...
sorry didn't want to hi-jack
Bobtile's thread,
but I kind of wanted to answer, clarify his question/statement...
