ksurfer2
When warmed up and idling in park/neutral, i need to set the idle speed to about 1800 rpm, this will net an rpm of about 1000rpm at idle in gear. Is this normal? Motor is a 512, 10.5:1 compression, solid flat tappet cam 600/600. dual eddy 1407's on a crossram. tci trans with a 3500 stall.
