bandit
What is the concensus on how far open to have the secondary plates? I was getting very little response on idle mix screws so backed the secondary plate screw all the way out to close them more and now it is too rich at idle and can't lean it out enough(eyes are burning in garage at idle). Mixture screws respond a lot better now though. The transfer slot on the secondaries is perfectly square with the adjusting screw all the way out. It will not go any more to cover it completely. Some say this slot should be closed, others say to open it up a bit to get the perfect square. Mine was running decent but had little response on mix screws with it more of a rectangle. What is the deal with correctly setting these secondaries? Doing a balancing act between too rich and good idle mixture screw response and rough idle and very little mixture screw response. Also, I could get 14in vacuum with them opened slightly but maxing at 10in with them closed to the perfect square.
Should I go for 14in with secondaries open more and lose a lot of response on idle mx screws or leave secondaries closed(perfect square showing) and go with the 10in and figure out this rich issue? All this started with me trying to smooth out my idle. Tempted to just open them back up and deal with the rough idle.
