Saginaw Power Steering pump
10:01 PM
Indiana
I have a 383 big block with a water pump housing #2205862 the early style. I am currently assembling the motor on the engine stand and basically mocking up the accessories. I have a saginaw power steering pump with lines attached to it currently. The is a 1966 Dodge Coronet that originally came with a 318. My question is what brackets do I need for the saginaw pump. Online I have found brackets for late 60's blocks with asaginaw pump. Can I make a saginaw pump work on this motor? It has a pulley on it currently. I noticed though the saginaws have a three spoke pulley. The one I have is a full circle pulley. What diameter pulley will I need for the saginaw pump?
Go to Bouchillon Performance (online)--they have everything you'll need with full explanations.
