- 1:12 PM
- Jan 29, 2018
- Midland Ontario, Canada
None of the above matters as the fella has no room for a permanent cabinet!
El Cheapo is an understatement but it's a good starting point. I found mine to be nearly impossibly to see anything in unless you use the shop vac port and it won't siphon any decent sized media without plugging. Use a vac and smaller media and it will get the job done. Later down the road I'm going to make mine where it draws the media from the bottom of the funnel instead of the annoying suction tube.Wire wheels can be very dangerous....
Harbor freight has an el cheapo cabinet that does the job for limited use for an budget.....
How did you keep the sand out?How I did my pumpkin as too heavy to put in the cabinet and need the pail to seal the glass out of the gear side. Shipping tub liner bag, but you could use a tarp with some folding.
View attachment 674472 View attachment 674473 View attachment 674474 View attachment 674475 View attachment 674476
How did you keep the sand out?![]()
