Secret Chimp
I have a bone-stock 1996 5.2 Magnum in my Coronet wagon. It is converted to carb via a 600cfm 4160 and a knockoff Air Gap intake, Doug's headers, 3.23 gears, newer tow converter (probably 2000-2100 stall). Car weighs about 4000 pounds with me in it.
I have been wanting to put a cam in it for awhile, but I kept just shopping Hughes and getting discouraged with an $800+ parts list for maybe another 40HP.
Recently I found I have been missing options for regrinds via Oregon Cams or other sources.
I'm thinking about using this grind that I saw a few folks throw in Magnum 360s, but with the kegger intake and FI vs carb (via this FABO thread):
#1990
224/230 @ 0.50
.510/ .510
112 LSA
As I understand I should be able to get away with just the regrind + Hughes' 1100 spring/retainer set?
I can find some people claiming you can run up to .520 lift with just changing the springs/retainers before you have to machine the guides. Others claim you can't go past .470 lift before clearance problems, though maybe they were talking about with stock springs/retainers.
My general goal is to improve low and mid-range power on the cheap for street fun, but I'm not sure what I should be considering lift/duration-wise with a Magnum 5.2/318 vs a 5.9/360 (since more people run 5.9s for Magnums, at least), no computer to monkey with, but something several hundred pounds heavier than an A-body coupe.
#1990
224/230 @ 0.50
.510/ .510
112 LSA
