Supershafts
Example: If you look down from the top of the car there should be no side to side deviation. The output shaft and pinion should be perfectly lined up. You only want the angle as you are looking from the side of the car. Since you have a tranny conversion make sure you don't somehow have a compound angle built in.
How is the slip yoke? You should not have excessive radial play.
Um you do know that EVERY mopar has the motor off set to the pass side, and that the angle you say shouldn't be is in EVERY mopar
This is the other reason i use ears and lose mounts when i get to them, so the motor is centered and the car is balanced correctly.
