UPDATE 7-23-21:
This afternoon was the time to try all this Energy Suspension stuff out (and it's sufficiently roasting hot
outside in the afternoons these days), so heck with work - to the garage I went, like I had made an
appointment or something (which is sort of what I have to do).
Instant review:
The
Energy Suspension 5.5135G conversion kit for 15/16" stock bar (hopefully this site's search
engine will find that for folks in the future) is a VERY well made piece. Everything was heavy duty, nicely
finished and none of the shiny, polished-looking hardware broke when I put the redneck mojo to it.
The adapter brackets in the kit line up sort of catty-corner with the two existing holes in the k-frame on
either side and once you figure out which side is which (they only go one way and they aren't marked
L or R), they locate the stock bar just the way they ought to.
(Note: the directions also say to drill a third hole in the k-frame for a third bolt for each side for the
adapter plates; the hardware got the heavy-gauge adapter and the bushing retainers plenty snug to the
k-frame though, so I didn't do that part - yet. If after driving it a few times it becomes evident that
third bolt is needed, I'll gladly do so - but keep in mind, the factory only had two bolts holding the original
bushing retainer, too).
Next came the link kits, formidable as they were - these things dwarf what was left of the factory pieces.
They are also "adjustable" from Energy Suspension in that they come with two pairs of "short" and two pairs
of "long" bushings - and you're supposed to figure out how to pair them up on the links.
Lacking anything more sophisticated to decide by, I determined that their "short" ones most closely resembled
the factory bushings I had for reference and used those on either side of the middle sleeve, in between
the LCA and the bar:
That seemed to work out sort of "naturally" within the space given.
Procedure (once I remembered that the hump in the bar goes UP, that is!):
I first loosely hung the bar from the k-frame bushings, then loosely assembled the link kits on either side...
I eyeballed side-to-side things, wiggled things around on their mounts, tried to find where the bar wanted
to rest "naturally" and still remain what appeared to be centered, then lowered the car to its' wheels.
The instructions say not to final tighten anything until the car is resting normally on the ground so once
I lowered it, I made any last minute adjustments, greased where there are fittings (and hosed down the links
with white lithium too, although the instructions say no lube is needed) and then laid the torque to all the
hardware.
While things didn't work out perfectly, exactly equal side to side (there's about a quarter-to-half an inch
difference in something when comparing side to other side), it was pretty darn close considering.
I know the LCA's are snug and good to go; that leaves slight warpage in the bar itself or even the k-frame
not exactly being gnat's-*** perfect, for that matter.
Either way, everything is certainly where it should be now and there's no more slop.
I'll put some miles on it, then in a couple weeks, re-check torque and re-grease whatever decides to squeak.
Conclusion:
If you want to retain your factory sway bar and your own frame mounted bar bushings are shot, snag one
of these Energy Suspension adapter kits. They're quite impressive, least to me.
(Now that I'm all done with any mechanical work up front - FINALLY - next project is to get under there with
detergent, scrubbing implements and have at it. It needs a good scrubbing!
