seat foam
Legendary interiors Newark NY
But they only make the front seats.
For rear you're going to have to get something close and shave it
Welcome to FBBO!
Rear or front buckets?
Rear buckets. I found what I need for the bottom seat cushion but what are people using for the upper rear seat cushion (seat back)? If using foam what size piece did you use( what dimensions was it cut to?) Thanks
Heavy felt cover over burlap. Then 1/2 inch foam.
Back seat used a thick batting and molded it around. Mine was in good shape so reused most and just added to some worn areas. Did reinforce some areas with burlap as shown in 2nd picture.
