FOR SALE Selling my 73 Charger
Coronet67guy
5:25 AM
Missouri
Need to make room for a Road Runner 340 so need to find this beautiful Charger a new home. This one is on eBay - Item number 332335579397. Any questions let me know.
  • Engine rebuilt, May 2016. - Motor bored .040, new pistons, valve springs, rings, cam bearings, HV oil pump, lifters, rod bearings, main bearings, resurfaced heads, timing chain set, freeze plugs.
  • Comp Cams 20-221-3 Xtreme Energy camshaft
  • Edelbrock Performer 2176 dual intake manifold
  • Edelbrock 1406 Performer 600 CFM 4-barrel carb
  • Ceramic coated Hedman headers
  • Yukon 3.21 ring and pinion set
  • New speedo gear so speedometer is accurate
  • Db Electrical super torque mini starter
  • BPE TorqueFlite kickdown cable
  • Rebuilt alternator with new rotor and bearings 12/2015
  • Mancini racing Prestolite distributor
  • AC Delco professional water pump
  • New headliner
  • Sway bar - 1 1/8 inch - no sway bar on original car
  • FirmFeel stage two steering box
  • Centric drilled/slotted rotors
  • Reinforced LCA's with new bushings
  • New strut rod bushings
  • Period correct green top Mopar battery
