sending unit
mightymopar
9:39 AM
WNY St.
Hi, New here. Is it possible to change the gasoline sending unit without dropping the fuel tank on a 67 Coronet?
I would say yes. I've changed them on '64 and '68 models without dropping the tank. Try to have a half tank of gas, or less, when you remove the unit.
I had to take the tank down on my '67 Belvedere II to change the unit. I also bought a 3/8" replacement sending unit from Vans Auto and it turned out the disc itself is stainless--couldn't solder a return line into it and had to have it welded.
A little bit of gymnastics to get the filler tube and tank vent lines out of the way, then once the tank was back in I found it difficult to press the filler tube back into the grommet on the tank. No leverage from behind to push down, but it eventually goes in.
B II
Lubricating the filler tube and grommet with liquid dish soap usually makes them easier to install.
