Cliff Ramsdell
Another thing to think about is cooler line size. The stock cooler lines were 5/16” and these were fine until the late 80’s when the A500 (42RH) and the A518 (46RH) came out and we started having failures in the overdrive. I believe the switch over to 3/8” lines was done in either ‘90 or ‘91 and this increased the volume of flow back to the transmission.
On the early pre OD units return lube was used to lube the gear sets on the output shaft. I don’t recall the return lube circuit on the OD units but we have one on the bench now and I’ll research that more.
All factory coolers mounted away from the radiator but in the air path. Some of the Dodge Ram trucks had a remote cooler under the truck bed right behind the cab area and a fan kit with a switch allowed it to run separately to help further cooling on the Diesel trucks.
Cliff Ramsdell
Cliff Ramsdell
