gkent
That’s not what the OP’s original post said which is why I’m asking to be sure.
Good point !!
Simply remove the screws holding the weight to the back of the dampner!Is there instructions explaining the cast crank removable weight? I am considering a new balancer for my 73 Charger, 318. I’m about to pull the timing cover and ensure the timing chain hasn’t jumped figure while I’m there I might as well replace the HB.
According to the manuf. they are universal! I think the shaft has the same dia. as the b/b, and hemi! Did you get yours to put on a small block? If you did and It won't work for you return it and I will refund your money! Just don't mess it up trying to put it on! SteveBig block and small block dampers are different. You can't use this one on a 318.
