Shaft Length and Penetration
Thunderlugs
1:08 AM
Burlington, WI
I have a 742 323 posi setup out of a 66 Charger. My 65 (Bell II)) axles ...., 741 housing 294 open diff. #1.... Are the splines the same? #2 lengths the same? or should I be looking to re use,, if I can find the axles out of the 66 setup. I have forgotten some of these details over the past couple of decades. Thanks in advance for the shaft input. (no pun intended)
Do you have the posi pins for the 742? should be no problem interchanging it If you do! The 65 housing is the narrowest in the B-bodies! Can remember if the axels or different in length! I have a pair of 66 axels if you need some!
